j0shua;537903 said:Full tank is about 80l. Should be good for 450km with mostly highway & 100km/h+ speeds. Range will obviously drop with traffic, and consumption would be quite high in heavily congested city driving. Plus points is that the V8 is smooth, and 330+hp is useful. Car does 140km/h in top gear @ 2500rpm, and 170km/h @ 3000rpm, so it's a real good highway cruiser. Will recommend 745 over 735 if you have a lot of cruising.
Maintenance isn't that bad, as long as you get one that's '05+. They would've worked out the issues by then. the 6HP gearbox always will have small issues, but before you buy, check for transmission slams as the car downshifts to a stop. Check for issues with the power steering, and air suspension. The car eats brakes a bit faster than you'd expect, but that's due to clamping 2 tons down from quite high speeds frequently. Don't take one without FBMWSH. Other than that, most electrical, A/C, engine systems seem to have held well for about 6 years, with no real problems in the horizon except for normal wear and tear on the suspension bushings and such.
JJTan;540207 said:I was told, the higher the engine displacement, the lower the resell value due to road tax. If not mistaken 745 is 8k+ under personal registration.
DigitalPunk;540348 said:Hi j0shua,
any idea about the 645i? 645i should b using the same engine as 745i I think. 645i is using N62B44, any know problem to this engine?
DigitalPunk;540371 said:yup. once driven the mighty 7s. there not many other cars u can change to. 2 weeks ago, there was this Bentley Flying Spur over take my car so smoothly. wonder how it feels to drive a W12 engine beast?!
j0shua;540290 said:Yes to both counts.
But it is hard to quantify the emotional value of cruising at 160km/h, under 3k rpm, with a v8 gently humming in the front as you sink into the perforated leather seats, with its air bladders gently massaging your bum as the air conditioning and seat ventilation keep you nicely chilled as others are sweating it out in the tropical sun, and knowing that you're driving a car that so many aspire to own but can only see once in a while, overtaking them in a blur of speed.
elwine30;540358 said:Once you have smitten by the 7 series, there is no TURNING BACK. .
Jamesc;538303 said:Thanks for the info, I'm cruising most of the time, north-south highway. I'm now thinking which to go 735 or745. The fuel consumption looks higher compare to my x5. Hope to get one soon. FBMWSCH?
j0shua;537903 said:Car does 140km/h in top gear @ 2500rpm, and 170km/h @ 3000rpm, so it's a real good highway cruiser.
