318is (M42) folks
affan66
Founding Member
Hey guys,Need to find some kakis who are using this engine.Where do you source for your parts?I am looking for some engine parts and in the future also looking for some E36 coupe parts. These are all wear & tear parts.I find it difficult to find these parts at shops like Bavarian Auto.Some hoses, body rubber...Also, anyone got the ori air filter housing and the related rubber parts from the front all the way to the MAF lying around taking up storage space and you don't know where to chuck it? I am looking for one to replace my open pod filter.PM me .. thanks.
First user reporting here... :D
btw, you want source parts for 318IS..., a piece of cake..., I know where
btw, I got an original M42 airfilter housing full set (since mine turbocharged then no use lor), dunno if nyam or not.
Anyone know where can get the Throttle position sensor for M42/M44 ???
Thanks
affan dude.... doesnt fabian use an iS in his e30? Could be wrong but his version may share some commonalities....
if can't find M42 parts here , then got to visit SG..
As for me, I haven't replaced anything that is M42 specific. the parts which I have been buying are mainly M40/42 components...
the 318is I am holding on to now is not tip-top as per my standards (heheh).
Fixing many of the fuel-related stuff as it is dangerous to drive around when there is a fuel leak.
Also working on fixing the idle problem.
The exhaust also got lubang but I think the exhaust is not OE.
Hehehe...bro...i am one of the owner of M42 also... remember? :rolleyes:
So far not much of problem to source the part leh... :)
Parts are easily available for the M42. What do you need specifically? :)
niki.. noisy leh...
exhaust also.. at 120++ so noisy...
Alb, where to find in Msia? which spare parts shop has it?
hi,i m running a e36 318is coupe m42..what ever parts u guys need just let me know..i could get all of them at a reasonable price
btw, IS parts can be sourced at BA Benz, Mutiara Damansara
McFir7, how much is a full set of new engine mounting?
Affan,
Try Inner power, bavarian auto, csc, comin, etc, M42 parts are rather easy to come by lar.......
hi guys, can someone tell me what's the different between e36Coupe and e36iS? are the engine running with timing belt or timing chain?
kindly advice, trima kasih manyak manyak...
M42, M43 and M44 all running on timing chains. M42 chain tensioner is prone to premature failure, better to replace it with M44 ones. Other than that, the engine is rock solid. Also, it shares valves and hydraulic lifters with the M50 engines.
looking for rear windscreen rubber moulding for the 318is coupe.
Anyone can source extremely quickly? please PM me or call if you have my num
Thanks
