19" wheel/tyre into F30
eric92penang
Could any sifu to confirm the following spec of 19" wheel/tyre can fix into F30 without problem/rubbingFront: 19" x 8.5" ET35, 235/35/19Rear: 19" x 9.5" ET45, 265/30/19
I am not too sure if the main driver door has a sticker indication next to the seat which tells the exact width of tyres. For example on the E90, they recommend that the rear tyre's width for 19" should be 255 instead of 265.
The offsets looks safe. Personally, the rear offset is not agressive enough. I think it should be about +38 so the wheel is almost flush with the body...
Jason
If u going for the super wide look at the rear, I know of folks that have fitted up to 275/30/19. A few have even gone extreme with 285 which looks outrageous. But if u happy with 265 then U shud go with 265/35/19. For the fronts u are ok with either 35/40 profile to maintain the required diameter.Jason
