X5 HID problem
X benz, thank for the SMD LED Angel thing..
Wow no inverter. Just connect directly to the low beam and it works.. :cool:
much brighter than my previous CCFL version.. No regret buying it.. Love it to bit.. :rock:
BTW, see you next week for HID for my fog lamp.. hee.. hee.. :rock::rock:
See picture below:
Daylight also can see. (below picture at different exposure around same time to see the LED Angel Eye)
X Benz;518950 said:
Jarance,
Thank you. I m happy that you liked the angel eye! see you on friday...! How is the juice! good?
The juice taste like ribena.. Dont think can see the benefit so soon.. Think I stick with my chiva..
Hi X-Benz, the hid comes out with low beam warning some time. And yesterday suddenly the left hid turn off while driving. So have to change the power cable?
X Benz;519531 said:
Bro,
Yes. Will change the power cable and check the connection to insure all connection are connected properly. Shall we do it tomorrow? Everything seems to going right now since not more rear selfleveling inactive warning doesn't light up anymore.
call me on tomolo fren. :rock:
bro, what type of HID are you using? Sometime the ballast of the HID is the cause of all the problem.
X-Benz installed a set of Korean Hid with Canbus ballast. Total RM700. I have to test few more days to ensure no problem.
If dont work ask for your money back... :rock::rock:
X Benz;519186 said:
Wow...looks better on your E46..! Cant wait to see your fog lights....! Want to do your DIY fog lights. ?
Just an update.. Just install the HID for the fog light after the right bulb have been changed. Fit like a glove without any modification.. Install the ballast just behind the bumper. Have to remove the headlight to mount the ballast. (The bracket that come with the ballast is handy)
Just install on one side to compare with original halogen bulb. Very bright as compare with original.. :rock:
Best thing is no sign of any alarm when switch on the fog light.. :rock:
X-benz thank for your community service.. :smokin:
wow, x benz many ppl buy HID from u ah. just to add, i am also happy with the HID bought from u, the "bulb out" error warning is finally solved, thanks.
Y? read the thread, hkh_88 problem seems unresolved, once u post a thread, u expect to find solution, does it matter whether the thread is 1 day old or 1 month old? I want to know if a solution is found.
If no solution is found, then hkh_88 can ask for his money back as what Jarance said earlier.
