when engine a bit shaking..what is the problem?
ELnino
my engine a bit shaking... change tepet not solve...change the engine heart also not improve...the shaking is not much compare to when u need to change mounting....but me n mechanics still cannot solve why it a bit shaking...
for u guys info.....i've just did top overhaul...but this shaking thing still there..
I'm assuming you plugged in the diagnostics machine to check ya?
Can be a number of things. What engine does your car have?
shaking? You never redline her, she is horny :) hehe. Could be many reasons including fuel pump, cam shaft sensor, distributor, pressure regulator etc! Since your mechanic not sure better get 2nd opinion.
AFM check...n it is OK...ouhhhhh...........engine is a bit shaking either cold or hot...it is the same as before top overhaul job...so since completed...my mechanic doesnot satisfy with this. keep searching for the problem...
what your RPM?
your vibration any changes when A/C is OFF or ON?
oh yeah, what type of engine do you have.
at last....my mechanic got advise from his fren..another conti mechanic..try to take off the visco fan...n that's it..the reason..so now the problem settle...need to change it..after he did a lot of checking
