ALBundy
Founding Member
- Dec 4, 2004
- 11,610
- 38
Tianci, best is change the rim with the offset you need. But generally with 18inch rims, don't think
you need anything more than 15mm. It also depends on the type of tires you have, some allow a more aggressive offset due to the sidewall design. For instance Conti CSC tires tapers off at the top of the side wall while the PSS is more squarish and hence it may rub against the fender with similar offset.
Go for it, better looks and handling
