m.azharm5
- Mar 6, 2009
- 167
The higher the ET number the more the wheel will sit inside the wheel arch.All ET/OFF SET is dependent on tyre and wheel size so bear this mind if trying to fit wheel from one model to another , also if the car lowered then you may have issues with rubbing/non fitment .1 Series E81/82/87/88 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 35-453 Series E21 = PCD 4x100, centre bore 57.0mm and M12x1.5 bolt thread. ET 12-203 Series E30 = PCD 4x100, centre bore 57.0mm and M12x1.5 bolt thread. ET 15-353 Series E30 M3 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 27-303 Series E36 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 30-403 Series E36 M3 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 30-403 Series E46 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 30-453 Series E46 M3 = PCD 5x120 centre bore 72.5mm and M12x1.5 bolt thread. ET 20-253 Series E90/91/92/93 = PCD 5x120, Centre bore 72.5mm and M12x1.5 bolt thread. ET 30-453 Series E90/92/93 M3 = PCD 5x120, Centre bore 72.5mm and M12x1.5 bolt thread. ET 34-375 Series E28 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 18-255 Series E34 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 13-205 Series E34 M5 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread.5 Series E39 = PCD 5x120, centre bore 74.0mm and M12x1.5 bolt thread. ET 15-255 Series E39 M5 = PCD 5x120, centre bore 72.5.0mm and M12x1.5 bolt thread. ET 15-255 Series E60/61 = PCD 5x120 centre bore 72.5mm and M12x1.5 bolt thread. ET 15-325 Series E60 M5 (Saloon) = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 12-325 Series E61 M5 (Touring) = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 12-326 Series E24 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread.6 Series E63/64 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 14-206 Series E63/64 M6 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 12-207 Series E32 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 19-267 Series E38 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 13-257 Series E65/66/67/68 = PCD 5x120, centre bore 72.5mm and M14x1.5 bolt thread. ET 15-258 Series E31 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread.X3 E83 = PCD 5x120, centre bore 72.5mm and M14x1.5 bolt thread. ET 40-45X5 E53 = PCD 5x120, centre bore 72.5mm and M14x1.5 bolt thread. ET 40-45X5 E70 = PCD 5x120, centre bore 74.0mm and M14x1.25 bolt thread. ET 37-53X6 E71 = PCD 5x120, centre bore FRONT 74.0mm, centre bore REAR 72.5mm and M14x1.5 bolt thread.Z1 E30Z = PCD 4x100, centre bore 57.0mm and M12x1.5 bolt thread.Z3 E36 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 30-40Z3 M Coupe/M Roadster = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread.Z4 E85 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 45-52Z8 E52 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread.:rock::burnout:
