my 2008 E92 clocking at 77k. anyone did their 80k major service? saw online E92 80k major service consist the following. any recommendation place for works below?
E9X 325i/xi, 328i/xi, 330i/xi Maintenance Service 80,000 Mile Major Service
-spark plug replacement
-ignition coil and coil boot inspection and replacement
-engine oil change with filter, using OE BMW 5W30 or Motul
-reset oil service/maintenance indicator
-air filter replacement or cleaning for aFe/K&N type
-fill and bleed cooling system
-manual transmission fluid change, using Red Line MTL or Motul 75W80
-differential fluid change, using Red Line 75/90 or Motul Gear300
-brake fluid flush/bleeding
-fuel filter, pressure regulator replacement
-serpentine belt replacement
-replace belt roller pulleys and belt tensioners
-complete chassis inspection, including: front control arms, tie rods, ball joints, wheel bearings, rear suspension arm bushings, rear upper shock mounts, rear subfra-me mounts, axle shaft boots
-complete brake system test and inspection
-engine and transmission leak detection and diagnosis
-shifter linkage, driveshaft guibo, CV, and center support bearing inspection
-exhast system inspection, including hanger replacement
-water pump and thermostat inspection or replacement. The water pump on this car is electric and will not display warning signs of impending failure. The output of- the water pump can be tested however, and your local full-service BMW repair shop should have the diagnostic tools to perform this test.
