what will cause heavy pickup ?
transporter
hi bros,may i know what will cause heavy pickup besides petrol filter and clutch fan ?i have changed both but my car still slow like turtle when pickup...appreciate ur help thanks bros
transporter;485860 said:
hi bros,
Urs 528 woor....heavy pickup meh? 528 should be able to :burnout: with it's torquey torque mah :smokin:
hi bros,
Instead of repair/pre-maintenance on a piece meal basis, send your car to a good reputable BWM workshop. Be prepared to fork out thousands of $$$$ if you want to bring your ride to a satisfactory performance level. Otherwise forget about owning a beemer:smokin::smokin:
Transporter, To avoid any speculation, can you tell us the time it take from 0 to100 km/hr on a level road.
mine is a 525i M54
0-100 havent timed it yet..
well, the car feel sluggish when pickup on a standstill..
i have experience better pickup before i took it to service and after i bought back the car, the car is slow like turtle on pickup...
transporter;486023 said:
mine is a 525i M54
torque converter...??
Maybe the gear is stuck at 2nd when at standstill in D. Transporter, try switching your gear into M mode and shift it to 1st. And throttle thereafter. Got difference?
mine is a 525i M54
do you know what the workshop did when u send your car for service?
eg. change oil or atf......
so many possibilities?
any possible specific cause ?
dun wanna fix 1 by 1 to find out... aredi spent too much on this beauty...
i go change leaking oil seal..then the mechanic took out my radiator to wash...
after that he blame the fan clutch too tight...then i went back and he changed for me a looser fan clutch for free..but the pickup is not as powerful as it used to be...
i experienced this before...
before this hapen to me, i sent my car for a major service+top ovehaul
after i collect mycar, it was very slow in pickup...at trafic light, even a 660 SLK can tapau me easily...
then i took my car to mspeed and found that my cam shaft was position/timing wrongly...
after he adjust the cam position back according to the tool he had, everything back to normal....
i dono how the camshaft position can run like that,hehe...ask my mech who did the service, he said he didnt touch on that at all...:dontknow:
