what does "7.5J" refer to?
c-square
when it comes to describing the measurement of a particular rim, there are a few sets of numbers, one of those is eg. "7.5J x 17". Whilst I know that the "17" refers to a 17 inch diameter size rims, what does the "7.5J" refer to?
the width of wheel which goes hand in hand with tyre width
Means the width of the rim is 7.5"
Rim width..
Hope this help: http://customwheelsmarket.com/rimwheelwidth1.html
Aspect
Ratio
Metric
Size Designations
Approved
Rim Width Ranges
35
Series
275/35R17
9.0-10.5
335/35R17
11.0-13.0
345/35R15
11.0-13.5
40
Series
285/40R15
11.0-13.5
215/40R15
7.0-8.5
245/40R17
8.0-9.5
255/40R17
8.5-10.0
265/40R17
8.5-10.0
235/40R18
8.0-9.5
45
Series
195/40R15
6.5-7.5
215/45R15
7.0-8.5
255/45R15
8.5-10.0
205/45R16
7.0
225/45R16
7.5-9.0
245/45R16
8.0-9.5
215/45R17
7.0-8.5
235/45R17
8.0-9.5
255/45R17
8.5-10.5
50
Series
175/50R13
5.0-6.0
195/50R14
5.5-7.0
205/50R15
5.5-7.5
215/50R15
6.0-7.5
225/50R15
6.0-8.0
195/50R16
5.5-7.0
205/50R16
5.5-7.5
225/50R16
6.0-8.0
235/50R16
6.5-8.5
215/50R17
6.5-7.5
55
Series
205/55R14
5.5-7.5
185/55R15
6.0-6.5
195/55R15
5.5-7.0
205/55R15
5.5-7.5
205/55R16
5.5-7.5
225/55R16
6.0-8.0
Aspect
Ratio
Metric
Size Designations
Approved
Rim Width Ranges
60
Series
185/60R13
[td ]
5.0-6.5
205/60R13
5.5-7.5
185/60R14
5.0-6.5
195/60R14
5.5-7.0
205/60R14
195/60R15
205/60R15
5.5-7.5
215/60R15
6.0-7.5
225/60R15
6.0-8.0
235/60R15
6.5-8.5
65
Series
185/65R15
5.0-6.5
195/65R15
5.5-7.0
205/65R15
5.5-7.5
215/65R15
6.0-7.5
70
Series
165/70R10
4.5-5.5
175/70R12
5.0-6.0
175/70R13
5.0-6.0
185/70R13
5.0-6.5
185/70R14
5.0-6.5
195/70R14
5.5-7.0
205/70R14
5.5-7.5
185/70R15
5.0-6.5
205/70R15
5.5-7.5
215/70R15
6.0-7.5
82
Series
155R12
4.0-5.0
155R13
4.0-5.5
165/70R13
4.0-5.5
175R14
4.5-6.0
185R14
4.5-6.0
165R15
4.0-5.5
[td ]
5.5-7.0
[/td]
[/td]
Automotive Suspension & Steering Systems, Thrid Edition wrote:
Flanges are made with different heights and curvatures to match the tire bead configuration. Flange type is designated by a classification system using one or two letters. The most commonly used flange heights are J= .68"(17.3mm), JJ=.69"(17.5mm), JK=.71"(18mm), K =.77(19.5mm), and L = .85"(21.6mm).
pussy;760288 said:
'J' is short form of the scientific name of 'radius'
"Radius" is represented by "r" lar!
http://en.wikipedia.org/wiki/Circle
As proved by Archimedes, the area enclosed by a circle is equal to that of a triangle whose base has the length of the circle's circumference and whose height equals the circle's radius,[3] which comes to π multiplied by the radius squared:
"J" however stands for "Joule"
http://en.wikipedia.org/wiki/Joule
The joule ( /ˈdʒuːl/ or sometimes /ˈdʒaʊl/); symbol J) is a derived unit of energy, work, or amount of heat in the International System of Units. It is equal to the energy expended (or work done) in applying a force of one newton through a distance of one meter (1 newton metre or N·m), or in passing an electric current of one ampere through a resistance of one ohm for one second.
... and it's totally irrelevant in this context. :thefinger:
during my time in school, we were taught that a circle's circumference is calculated using the formula 2πj, and its area using πj squared.
of course those days the subject wasn't called maths, but ilmu hisab; and j therefore is 'jejari' or radius.
Ops.. now I remember.. haha! Correct.. :top:
astroboy;760158 said:
Rim width..
Oh, one more thing....
Based on the image above, does it mean that with a tyre of say 225/50/17 on a 7.5J x 17 rims, the tyre will bulge out about 35mm (17.5mm on either side) since the rim width is only 17.5 inches (about 190mm) compared to the tyre which is 225mm?
hello kawan-kawan. i wondered about this "j" question too when first coming across it a while ago.
here's an excerpt of an article i found which gave me a satisfying answer:
it is the letter that typically sits between the rim width and diameter figures stamped on the wheel, and indicates the physical shape of the wheel where the tyre bead meets it.
full article here, which a heck of a lot of other good information. http://www.carbibles.com/tyre_bible_pg4.html
key point to note - make sure your rims & tyres have the same profile stamp, otherwise they wont fit! :)
c-square. yup, a bigger tyre width will bulge out of your rims. check fitment to ensure that you are first able to put them onto the rims. if you can, you'll have added protection from kerbing your alloys :)
radius = jejari !
yup, so long never heard the word jejari..but tapi takkanlah mat salleh pakai malay word jejari as the 'J' here..?
