What Brand HID is Compatible ?
limcg88
hi all, What Taiwan / China Aftermarket HID set kit is compatible to BMW E90 320i ?Install without any warning on dashboard when on the light....
Look out for the ballast that is canbus friendly, but i tot all E90 comes with hid?
limcg88;618059 said:
hi all,
My E39 pakai Osram kit. Bright but not glaring. There should be one compatible for your E90 too. Warning side, mech add a lil bulb, no warning anymore.
how much you bought your osram HID kit ?
What you mean " Warning side, mech add a lil bulb, no warning anymore. " ??
RM1.2k inclusive installation.
That means no more "check headlamp" warning light after adding a small light bulb to the circuit.
If you keen, spend me a nice teh-tarik, you can have a look at how it shines hehe ;-)
Cheers,
seewai
is anyone here know where to buy the D2S convert to H7 holder ? i have a set of D2S which i planning to install into my E39.
woo~~ 1.2k is out of my budget...I'm going to save some budget and find those taiwan/china HID kit which is suitable and compatible for BMW car which can install without "check lamp" warning apear.
bro, any idea to those china/taiwan HID set ?
cheers...
cheers...
Itu Osram memang China mali. Sorry bro cheaper ones I've no jalan.:106:
Recently, i found a Philips HID set which is cost around RM 400 and the seller said is made in Taiwan but the bulb is not from philips.
bro, yours is also Osram bulb ??
limcg88;618374 said:
Malaysia got selling canbus HID set for Fog Lamp ? How much per set ?
Got, WRC selling full set at RM6XX or less, forgotten already. use it for more than a year no problem at all
better buy from ebay, less than RM50 if i'm not mistaken
It is not necessary to use canbus HID for Fog light. Front low beam required Canbus HID to eliminated the "check lamp" error.
bro, check the focal length of the D2S and H7 bulb first. A few mm difference in the focal length will render your light pattern useless.
ya, i need to to eliminated the "check lamp" error after install the HID to avoid automatically cut off the light.
Other than canbus HID, any more cheaper HID set is compatible to eliminated the "check lamp" error ??
