moots;829677 said:oh oh not good bro....red zone is danger zone....
scanning will turn up nothing as all these are purely mechanical...
i suspect bleeding not done correctly.boiling water means trouble.is yr thermostat working fine?try the "boil thermostat in periok" trick to see if it opens....
anaksarawak;829686 said:Did your engine shakes in the morning? When is the last time you changed your water pump. Have it properly checked bro
if only thermostat is ok............i scared is water pumpVolvos525i;829687 said:Wooooo not good lije bro moots say is true...
Is the bleeding done correctly...
Do u check ur thermostate...
Mine change thermistate during changing heater inlet n outlet pipe....
Think ur thermostate may be kaput oledy....
Aku ada stereng bas ko adaaa....
Volvos525i;829716 said:Bleeding should be at the 2 bleeding screw 1 at expansdion the other at the hose just b4 the thermostate housung...
1sr bleed the screw at the thermostate until coolant comes out then tughten back...
2nd bleed the screw next to expanssion tank until coolants comes out then u r done...
Volvos525i;829743 said:Bro Tweiboon...
Have u ever change ur thermostate housing?
Also the heater inlet pipe n outlet pipe?
If not please make it in ur list of to do...
wingzee;829775 said:bro tweiboon, just change both thermostats and see how it goes. I suspect it's either that or the water pump. Any grinding sound coming from the pump? That may indicate a pump bearing failure which is quite common for our cars at these age.
Best case is to do a complete cooling system overhaul, if you have not done so yet.
tweiboon;829734 said:Just done the bleeding with 2 bolts. Test idling is ok but when drove out water boiled again.
moots;829818 said:idle ok but once driven it overheats....my suspicion is the waterpump.
you may have the plastic impeller pump.over time the impeller lets itself loose from the shaft.at idle it still circulates the coolant somewhat but once on the go the impeller will not be able to do its job.
plse dont let the temps go even near the red zone coz if the head is damaged...its game over...
