Water seal broken!
Ade
The rear lights where the rear fog lamp is has been collecting water...any idea if its repairable? Can I just buy that instead of the whole rear lamp? How much is the cost?
try some glue.. some good glue...from ACE..
better see if it's a crack..hairline cracks maybe repairable... unless the sun is too hot.. nothing can with stand it...
the plastics are ok...the rubber seals..where can I get it? there appears to be cracks in the seal where the clear plastics and body meets..
Ade, that's what i said...
the rubber seal is to prevent the water getting into the boot, not into the lights...
Dear all sifus,
today tested an e60 523i during raining. after test drive, i removed the battery cover and found that water came in from ventilation hole above battery and also from found water from the other side ventilation as well..I don't think it is normal...need advise...
