astroboy
Well-Known Member
- Dec 15, 2006
- 8,734
- 63
The box works!
If you want to know if the box works for u, very easy to test. Go hook up a volt meter to your ciggy lighter outlet and drive around with it. U will notice the reading varies from 9V-14V depending on different situation. If u keep seeing 12V-14V, then yes, the VS will have no effect on u. But if you see 9V when aircond cuts in or going up Genting at night, blasting aircond, then this VS will give u wonderful result by improving from 9V-14V to 10V-14V, strap one more and your get 11V-14V, keep adding and you will get closer to 12V or 13V if you have the budget and engine space..
I have a friend running 4 boxes of 56 capacitors each!!! Home made VS! He would have added the 5th if space allowed.
If you can reach 12V-14V, then I congratulate u! U now gets a balance spark plug firing which is very critical for keeping up your torque compare to another 9V-14V car of the same engine. If your voltage is not stable, it will scramble the engine firing rhythms. Your lose torque!
I have not tried it on E90 though.. damn scary looking at the battery connector. Scared the air bags deploy when I meddle with the connector..
