AmoiSky
Official Member
- Dec 19, 2012
- 619
- 28
rezzsya;834095 said:boleh masuk e28 tak ni:burnout:
Offset 35.. U can check if it can fit..
front cant fit,but rear can..:smokin:AmoiSky;834097 said:Offset 35.. U can check if it can fit..
SilverBullet;834075 said:most M3's will have a more aggressive offset because of the widebody, hence all standard e46 wheels can fit M3s but not the other way around (will cause rubbing issues if u fit M3's rims on a standard e46..unless convert to widebody which is another racun chapter)..the stance using a non-m3 rims will look less aggressive on an M3..buuuut, you can still achieve the desired stance and offset 20 by using a 15mm spacer on the 35 offset rims![]()
