symptoms:vibration felt thruout cabin when braking but steering wheel no vibration.replaced rear brake discs and problem solved.my rh rear brake calipers were partially jammed,dragging the brakes and therefore warping the disc due to friction heat.the cause of the jam is due to a blocked caliper hose.disc - rm100/piecehose - rm40/piecemechanic - kenny of mspeed
