stormbringer
- May 7, 2005
- 12
Calling all Honourable Sifu's / Guru's,pls give me some light on this symtom .My ride is a 2001 p/fl 325i.The problem I am facing is my steering has this tendency to wrench / pull side to side when there are slight or serious undulations on the road.Also , I notice that the car is not as stable at speeds above 130 km/h unlike the early years when I could push it to higher speeds and it wasn't as nerve wrecking.My ride is shod with PP2 235/45/17 and used to be at 32 psi but after some experimenting its at 30 psi now,it has some improvement but still not enough.My lower control arm bush was also change to the PU Type but all in vain the problem still persists.Even the steering rack was tightened,but even this did not help.My ride is still on its original absorbers,and could this be the problem???? Pls,OOHHH mighty Sifus' / Gurus' of the Forum,bless me with your Knowledge and Wisdom for me to rid my UDM of this problem.I missss the good old days of not having to lift off the throttle unless I wanted to and not because I HAD to.All inputs would be appreciated,THANKS IN ANTICIPATION.
