Hi Alan,
Sorry just saw this.
1. A question. If I can smell petrol right after a full fillup (right to the brim fillup), doesn't it mean that the breather hose is working? As in, there's alot of petrol, so there's alot of vapour, and so alot of vapour escapes the car, so you can smell that? The breather concept is to let trapped air to release itself near to inlet which is still technically in the tank, when u close back the cap, it should be closed and no smell. but now the breather hose is leaking, causing a non closed loop. so even cap is closed, the pressure and movement from fuel line will cause fuel to spill out from this point. hence .. the smell.
2. Where is the breather hose located on the E34 and how do I change it ? Is it an easy DIY ? I will not suggest DIY this as dropping the fuel tank, needs a few pairs of hand. yes you need to drop the tank and disconnect the fuel line to get to this. its located near the filling inlet
3. Instead of the breather hose leading out the outside of the car - can we feed a long thin hose from the breather to the engine, and stick it into the airbox or intake manifold or something - so that the fuel vapours are not 'wasted' ? The E34 did not come with a vapour recovery system - I think that came with the subsequent generation. by now you should noticed Breather hose is located at tank and it is closed loop in the tank.
Thanks.
Breather is actually to let the bubbles created when flow comes into tank to rise without choking the path of fuel flowing in from nozzle when filling up.
