trust-one;678823 said:
PM Auto ...shop in bangi.
Which tread? I tried to search but can find any specific thread?
you were wondering why nobody answered you in this thread, because i supposed they wont' tell you cos they dun know.
actually, any experinced mechanic would be able to settle the wires from a left hand to a right hand.. there is a few examples of e30 owners driving around.
Your mechanic should have advised before you bought a left hand half-cut and now he needs a righthand wiring loom.
you should have consulted a few members here before putting in a shop that has no experince of this type of conversion, hence i know a handful of mechanic's with good wiring hands will able to sort it out.
by the way, you still can use the L-Jet fuse wiring loom without touching everything below the dash...
if you look at the C-101 plug, which connects the engine wiring to the ecu loom info line, the Motoronic uses about 14pins of connection, where else the L-Jet uses 7 wires only. connect that. if your mechanic can't do that, pull your car out from shop and move to one that can sort it out.
that's much i can help you, the rest is in your hands...
