http://www.youtube.com/watch?v=DY0PURMitfw&feature=youtube_gdata_playerAnyone had this problem before? I read that it's because the CV joint is out of grease.
Lithium2;814703 said:http://www.youtube.com/watch?v=DY0PURMitfw&feature=youtube_gdata_player
huskar3399;820437 said:i think my car behaves the same la. but the sound is not too loud (maybe because i am inside the car). is it bad if we just let it be? and is it easy to diy?
thanks for the heads up on the possible impacts bro. i shall start study how to diy the problem i guess. hope it does not require any fancy tools to do. hehe.Volvos525i;820440 said:Bro just my 3 cents...
At the moment the sound is not to bad...
Later on the sound becomes more louder due to the wear and tear more...
This long shaft rotates according to your driving speed...
There is centre bearing and CV joints with pin bearing inside...
The centre bearing will holds the long shaft as straight as possible during rotation while the CV joints to counter the rotation flexiblity...
The flange from the GB end is not straight to the rear axle...
p/s DIY...needs quite an effort....
huskar3399;820442 said:thanks for the heads up on the possible impacts bro. i shall start study how to diy the problem i guess. hope it does not require any fancy tools to do. hehe.
mael_WEK;832338 said:faced the same problem before..
replaced my long shaft full set (for 5hp19 gearbox) last May
bought from chop shop for rm680
labour charge rm60
albert from wp auto oredi dismantled & checked but nothing can do with it
found that too much free play oredi at the joints
cv joint itself cost about 1k or more
replaced full set from chop shop & problem solved...
Yes...conned. You can get it done for 150.alive88 said:bro lithium,if u still remember we met the other day(months actually) at yazmeen's place. heard that sound from ur car n wanna tell u bout it. Its the same thing happened to my car nd i have fixed it at bomin. its the constant-velocity making the sound. in layman's term. the cv joint. to replace might cost 1k+, but he took it out and serviced it for 250. walla, no sound till today. tell me if i was conned. hahah
No need replacement. It's out of grease if it's the same sound as the video posted above. Recommended countless E39s to Naidu (next to KWSP, jalan gasing) with that same sound.VT8525 said:Hi Sifu's, am facing this problem now.. and accordinglly needs a long shaft replacement. Am staying in PJ and just took my car to MPerformance at KJ for a complete radiator over haul.. want to get a 2nd opinion.. anyone has done a repalcement or repaired this problem.. before I invest on a long-shaft? Can you recommend the mechanic shop that did this for you please?
You're welcome VT. Good to know you're happy with his service and that the problem is solved.VT8525 said:Tuan Bimmerholic!!
Thank you.. problem solved. A good service and a change of couplings!! RM500!! Naidu is worth every penny.. also did the front windshield rubber change with him.. just bought the parts.. only change labour..
THANK YOU SIR BIMMERHOLIC!!
