C crusher Club Guest Joined Dec 11, 2004 Messages 656 Points 18 Feb 27, 2017 #1 Anybody found a fix for this problem? My right tail lights fail intermittently. It will come on again if when I move the bulbs or the housing but eventually fail again after a few hours. Its not the bulb.
Rick Wong Club Guest Joined Feb 12, 2013 Messages 38 Points 8 Mar 6, 2017 #2 check the base, any rusty or poor connection, i have the problem before.
jarance Founding Member Joined Dec 4, 2004 Messages 14,743 Points 63 Location KLlang Mar 6, 2017 #3 1. check your bulb base. It could be slight distorted. Slightly sand it down if it is. 2. check the holder of the bulb for worn out contact.
C crusher Club Guest Joined Dec 11, 2004 Messages 656 Points 18 Mar 26, 2017 #4 Its something to do with grounding, quite common problem if you google it. Got it fixed for RM20.00
