suspension....
who knows market price adjustable suspension for e30???
prefer brand...
bilstein...
ohlin...
tein...
huhuhu...
problemo solve...
hehehehe..
thanks...
now how to adjust e30 front chamber???
coz my left tire is -1.2 but right is -3.6...
how to solve the problem???
There is a shop in Sunway which they used a hydraulic jack to adjust the chamber. but the guy didnt do for my back wheel
yup...they use hydraulic jack to press the camber back to normal position. i think all 4x4 workshop have this jack. my car oso got problem camber out at rear wheel & now already ok after press the camber.
-3.6 so 'kangkang' bro...
how much for jack dis absorber????
now i got little bit kegawatan...
so need survey the price...
thanks for the ideas...
Around 80 ~ 100 per side,depend to ur camber out... not include alignment cost.
The camber on E30's are NOT adjustable gentlemen. The so called adjustment of your cars camber with the use of a hydraulic pump will only serve to destroy the already worn out rubber bushes on your suspension.
My advice is to replace all your suspension bushes as i have done. This will restore your suspension (and camber) to factory fit, provided your chassis has not suffered any damage.
i think you can go for custom made adjustable...and tell them how many degree camber that you prefer, they will try to make the location of the screw different abit... but need to find those who willing to do it for you...
i just heard someone tell me...
one brand can make the custom made suspension...
i not sure... i think
TITAN..
who know this brand??
lol now i know why my snow white is kengkang...
few week ago my brother drive my car...
die pergi langgar divider sblh kanan...
padan la i perasan depan blkg tayar baru...
wah tention nyer...
da dekat 2 weeks...
hari ni bru nk kasi taw... !@#$%^& punya brother...
any one can give another option???
to repair front chamber...
in my head just want to change...
used part
-front lower arm...
-bushed..
-absorber..
nk wat cm mana....
da nasib...
seday tul...
bru ingat nk kompol duit wat project restoration...
da jdi cm nih...
adoi....
Oh...too bad... next time is better not to let the other drive your E30, need some skills to drive that car especially rainy day... and dun be like that bro, just ask your brother share with the replacement cost, is not cheap to change the parts that you mentioned.
and i just found the E36 lower arm price is about rm120 in a chop shop in Ampang. some said is interchangable... hope it helps.
Bro...try to check mudah.com,found completed used front lower arm want to sell & oso front absober for e30 like new...good luck!
PaaN404040;437029 said:
oooo...
thanks...
bushes???
can u show me where is the bushes....
Well actually your car's (any car) suspension is primarily made up of bushes. These bushes attach AND isolate the suspension from the chassis. The springs are also part of this suspension system while the aborbers merely dampen the spring rate and dissipate the energy stored in them slowly.
You can view these bushes from underneath your car.
Check out my project at:
http://virtualmystic.wordpress.com/2009/02/
