Sun Roof Experts!!
ALBundy
Founding Member
Anyone know any mechanics that are deemed to be experts in this area??Thanks.
Thanks.
Aper problem ?
Not an expert but had my share with my 'bumbung matahari'
Baru tukar bumbung, tapi tak rata...masuk angin..kena buat la sikit adjustment :ph34r:
Same with me ...
I hv changed ;
1) The rubber lining
2) Drainage (clean it laaa ..) pipe
3) Motor - because bila tutup, cannot align.
But after 1, 2 and 3 - so far so good.
Try tanya Ah Wai ..
aiya.. if your sun roof cannot close... then weld it lah..
or
use umbrella during rain..
>>> cabuz>
or
>>> cabuz>
jealous laa tuu ... :yes:
Wat is wrong with this mr dien...asyik promo jer....moderatorz....
535i,
Bro how much did you get for the rubber lining & where did you get it from?
Thanks
miepower said:
535i,
Thanks
i think it was RM 270 (or 370) - from Bavarian Auto sometime back
Need to replace mine soon as its about to give in. Dont want to wait till my ride become a mobile acquarium. Anyway thanks for the info guys.
BTW, 535i/M30 is the installation DIYable??
Thanks
Thanks
Yes ... but u really need to be good. Taking out the old one might give some problem .. due to aging.
advisable to remove the whole roof then it would be easier, but unless you have 'rubber hands' like 535i, you can try changing it when the roof is on tilt and partly slide to the back:D
ayoo sunroof ...sweet ..going to install one soon someday..any lubang for this ??
but me worried one problem ...cannot drive when a sardarji with a turban sits at the passenger seat and the roof is open ....:)
got lubang......, its up on your head mate....:p
technical solution: get sarrdaji to wopen turrban when you wopen the sunn-roof larr....:p
Thanks
Speaking about mobile acquarium...mine became just that coz the drainage hole was stuck on all sides:( ...so when it rain heavily my car will rain inside also....i clean out the hole and was fine...i did not replace the rubber but it looks easy to replace. According to my friend the rubber is only to block out the wind sound when driving at high speeds.
