steering vibrate
sgojita4
Hello guys..
Happy labour day.
I got some problem with my ride. When i turn my steering towards left i heard some noise from my wheels.. like i was on uneven road. Do u guys know what is the reason for that? And also during braking,also i heard that noise..
Thanks guys
ayo....noise difficult to diagnose thru the net la bro,if you can describe tha noise then perhaps we can suggest something...
Bro Moots, my e60 LCI oso have this kind of issue..when turn the to left in slow pace it came with some rubbing sounds..it is not loud n can be heard from driver seat only..
Thanks for your reply bos. when i took left turn,my car will get shaking from right tire and got sound gook gook gook like when u are on small hump on the road.. i suspect maybe lower arm but not so sure.
sgojita4,
most likely your thrust arm/upper arm bush or ball joint.
but could also be your track rod/lower arm
could also be your anti roll bar tie rod
Mine also feel the same but make sound like 'ketak' wheen i hit a bump...and only feel it on my lef front wheel
