FIRZ67
- Dec 28, 2006
- 399
Previously my car had a problem with noise at door seal area and the proposed solution by AB is :1.Change rain gutter -the most expensive countermeasure.2.Change door seal- cost equivalent as above3.Put 3M Teflon tape at door seal area-DONE but only minimise the sound4.Lubricate the door seal with Rubber grease or silicon.-This solutions is the cheapest and it works BUT it only last for a week.After trying trouble shooting all the noise from door area, now the new squeaking noise started coming from the gear console.I've tried to open the gear console cover (silver trim) by removing the gear knob. It is quite simple to open but nothing inside there any parts that is loose or rubbing each other.Any of our E90 owner here experienced the same problem probably can share their counter measure.Thanks & Cheers
