That is really expensive bro. What is the point of sending the info to Germany for someone else to remap. Can't Eurotuner as per their name remap for you there and then? What happens if the new map comes back and is not to your liking? Do you just take it or can you reject it? Does it take another week for another map to be installed?
As Herbert said, Bernard is a lot cheaper and he will remap there and then and will only take your money when you are happy with the map. Plus for engines using the Siemens MS 43/42 ECU, it only takes about 2 minutes for your data to be captured. He will then, after getting information from you on what you are looking for, go up to his room and remap and come up with 2-3 different maps. This would take about 30-45 minutes. Installing the map is also quite fast, about 10 minutes. He then goes with you as you test your car. It is here that you tell him whether, you are happy or not. If you are not happy, he will install the other map and so on until you are satisfied. To me this is better service than what Eurotuner is offering and for fraction of the price.
