hi all,
i will soon be joining the bandwagon with a 330ci with ori sports kit.
i will prolly change do a 1 round service which covers (do advise if i may have left out any):
- engine oil change
- gear/atf oil flushed
- brake pads
- spark plugs
- oil filter change
- air filter change
- air con service
1) for engine and atf oil, i have been using torco on my current ride (toyota). can i use the same oil on hte bimmer?
The main consensus is that as long it's 30-40W weight range and it is LL-01 you're good to go. Otherwise any fully synthetics oil will be good as well. The main thing is to have a regular oil change intervals (OCI) every 5k-10k km. If i'm not mistaken Torco also have it's LL-xx range of oil too for BMW's.
For ATF better stick to the original fluids by BMW. Also do change your axle oil too, am using Redlines 75W-90 gear oil
2) i am looking for a brake pad that could withstand hard braking. any suggestion?
BMW original brake pads are the best as it provides great initial bite and stopping power. But you didn't say whether you're going to track the car or not ... and brake pads are just one of the equations. You could go for BMW performance rotors or aftermarket rotors like brembo's (RM2k last time i heard), steel braided brake lines, high perfromance brake fluids and etc.
3) i had quite a bit of handling mods made to my toyota (aftermarket coilovers, strut bars and antiroll bar). the beemer IMO, handles heavier than the toyota and i feel that it is not very responsive when manouvering tight corners (or maybe i am not used to it yet). therefore, do you suggest i swap the ori sports suspension for aftermarket coilovers?
My suggestion is to learn about the behaviour of the car 1st ... Get used to it's strength and weaknesses. Only then you could truly appreciate and understand a coilovers does to your car. I'm still on M-Tech suspensions and will be changing to aftermarket once it's shot. Besides coilovers get an adjustable Anti Roll-Bar like H&R or Eibachs, front and rear struts, front and real control arm bushings by powerflex
4) sometimes i can hear a 'krok krok' sound coming from the steering wheel, as if the steering is not solid. anyone with similar issues?
Not sure about that ... Maybe other members can chime in
4) which workshop do you suggest i send my new ride for service? i will need them to be able to help me fix any issue that i could discover with that car.
Please refer to the many threads dedicated to workshops and e46 maintenance.
http://www.bmwclubmalaysia.com/forums/showthread.php?t=246&highlight=workshops
