Good day to all.I'm sure most of you know about the inherent problem of the Z4 soft top especially for build prior 2006. Two common problem are water ingestion in the motor housing and hydraulic leak. I had my motor checked recently and true enough it was ingress with water. Its amazing the motor still work! So if you have the time it might not be a bad idea to check your soft top motor. Cheers.
