musclehedz
- Apr 22, 2005
- 399
What are the signs of the battery that is going to die off?In my previous car, one of the signs was the ABS indicator takes like 1 second to go off after the engine is started.
Mine's MF but don't have indicator.Originally posted by jeffreyewe@Jun 28 2005, 09:24 AM
As what supergripen mentioned earlier, if you have the battery with the indicator..life is so much easier.
But, if you have the normal one...usually the cockpit lights are dim and harder to start in the morning. These are the usual signs.
Originally posted by affan66@Jun 28 2005, 09:35 AM
Muscle,
I had that problem before, it was scary.
It could be a different problem but this was what happened in my case:
It happened during starting when I had problems with my engine. My engine overheated and had a cracked cylinder head. Upon starting, the car sputters and putters. The dashboard lights flickered and the OBC showed Check Coolant.
Do a reset of your DME and check with a diagnostic tool.
Originally posted by musclehedz+Jun 28 2005, 09:41 AM-->QUOTE (musclehedz @ Jun 28 2005, 09:41 AM)
Ya, tha'ts why i was guessing maybe could be the battery as my previous car had the similiar signs.Originally posted by flash@Jun 28 2005, 09:50 AM
Take it easy bro, don't jump to conclusion. In affan's case, he would be loosing water big time and his engine is definitely now running well. In your case, I presume that your engine is still running smooth.
I had that "cuckoo" dashboard syndrome once for a period of time with my ex-Babe. My RPM meter went haywire, intermittent error messages from the OBC (all sorts of problem came up), ABS off and on. These went on intermittently for period of a week or so and then mysteriously disappeared. It was ok until I got rid of the car.
BUt I hazard a guess... how old is your battery? A weak battery once caused havoc in my Wira.
Where's the indicator located?Originally posted by supergripen@Jun 27 2005, 08:17 PM
well my car's batt has got this wear indicator that goes from green(OK) to black(gone!!)..its one of those maint'free types.
my E36 last time gave no clue that i know of..started nicely everytime.suddenly one day it juz gave up..quite leceh la.
Originally posted by mini_jeff67+Jun 30 2005, 09:07 AM-->QUOTE (mini_jeff67 @ Jun 30 2005, 09:07 AM)
