ehoe
- Dec 8, 2004
- 308
Is there anyway to check if a absorber is worn out and in need of replacement besides the 'push test' whereby you push the absorber down and the car should only bounce once to return to its normal position?. My E34 front right absorber seems to have this scraping noise when I am going over bumps at a 45 degree angle. But the funny this is it only happen when I go over a bump or incline at an angle, if I drive straight onto the bump, there is no noise. Have checked the suspension components (i.e upper & lower arm, bushings, tie rod, etc) and all seems ok so I suspect could be the absorber. Anyone come across this symtoms before?.TIA... to all the sifu's.
