Selling E46 N42 Engine, GM Gear box (A) & etc due to conversion
Vincent Hor
I have decided to convert our E46 318 N42 to M54. Thus, I will have lots of parts from the N42 for sale.
Car has only covered 117,XXX genuine kms. It has been superbly maintained. Engine does not consume engine oil and no oil leaks. GB shifts very smooth. No delay in gear engagement whether in R or D even on the very 1st start of a cold morning. ATF & filter just replaced 4,000 kms ago. Next replacement due in 21,000 kms. All service records at WP Auto.
There will be too many parts to list but here are some of the major ones.
1. Engine
2. GM Auto Gearbox
3. Entire cooling system
4. Sensors Crank, cams (replace not too long ago)
5. Propeller shaft (Long shaft)
6. Rear differential
7. Drive shafts
8. Complete exhaust system
9. Air cond system
10. Etc
Everything is still on the car now. Expected to start work on the conversion in Mid November. So if any one interested here's your chance to test out the things on this car.
Parts will be sold cheap.
As per BMWCM rules in classified, I will list the price of following major item
1. Engine RM2500 - Booked. Deposit received 3/3/2015
2. GB includes the torque converter RM2500 - SOLD
Rest just PM with reasonable offers. Or just give me a call 016-2258831 Vincent Hor
Wah. how about aircond system. Got price?
Sent from my GT-N7100 using Tapatalk
What part of the AC system? Compressor, cooling coil, blower motor, control panel, condensor, hoses?
Compressor and hoses I think. I got an issue with my aircond. Last time it got leaking, after check cooling coil spoil di, replace then ok for 2 month. Now showing the symptom of leaking again cause driver side giving less cold aircond then the passenger side.
Are you referring to the high pressure & low pressure hose? Well you can have the compressor, high & low pressure hose for cheap cheap RM250.00 My air cond system system works perfectly.
You can reach me at 0162258831
Thanks Vincent. Take the parts di. At first they provide wrong item. Lucky I confirm back lol
I am sure got other things can buy from u but not sure which part now.
You are welcome. Lots of other parts still available.
1. Air Cond compressor - Sold
2. lamda sensor pre & post cat - Sold
3. Steering rack - Sold
4. GM Auto. Tranny including the torque converter - SOLD
Still got lots of parts available. Christmas & year end sale.
Clearing these items
1. Plug coils - RM40 each.
2. Radiator Hoses all 4 pieces, relatively new & in good condition - SOLD 16/12/2014
3. Power steering pump - RM400
4. Throttle housing - RM250
5. Complete exhaust system from exhaust manifold with catalytic converter to Breyton tail pipe - RM650
6. Electric Fan - RM350
7. Centre Console Arm rest with cup holders - RM150 - BOOKED 16/12 - SOLD 20/12/2014
8. Piano black interior trims complete set - RM350
9. Interior A, B & C pillar - Grey Colour in good condition - SOLD 16/12/2014
10. meter Cluster for N42 - RM400
11. Head light assembly pre face lift from the donor car (Amber) - in very good condition - RM200 for pair
12. Air Mass sensor N42 - RM300
13. Brake Servo - RM200
14. brake Vacuum pump - RM200
15. Rear differential 3.46 ratio - RM400
16. Propeller Shaft from GB to rear diff - RM400
17. Trunk / Booth lid grip - RM200
18. GM 5 Speed Auto Transmission - SOLD 20/12/2014
19. Engine oil sump protection plate - SOLD 20/12/2014
20. Water Pump FOC thermostat - SOLD 20/12/2014
21. Starter - RM250
22. Pre facelift tail lights from the donor car (Amber) - RM300 pair
Please enquire by PM or mobile 016-2258831 if you are looking for something for the E46 but not listed here.
Apologies to all who had SMS to me today. I inadvertently wrongly stated mobile no.
It should read as 016-2258831.
I have since edited my post.
Listing updated today. See post # 14
Many many more items available. If you require some plastic covers or small items just PM me. May even give it FOC. Else I will just throw them away.
The available engine is in super condition. Never consume engine oil. Never ever overheated. Interested parties please grab this quick. I have pics of the engine internals ( super clean & no oil sludge) when I replaced the valve cover gasket & oil sump gasket. All engine oil seals has also been replaced recently. Flywheel oil seal is new.
Send me a SMS & I will forward to you the pics of engine internal.
Super deal with super clean engine. I seen the pic of engine
Mcm anak dara
some of the picture I got from Vincent.
