AndrewMals
- Aug 29, 2010
- 31
Hi lads, Ive done the one seat now-Its a non.el seat, but does have side bolster controls. This is where you can pump the sides up to "hold" you more.The adaption is simple enoughThe wiring from the seat itself has a yellow multi connector, this is an outershell, as there are different connector "modules" housed inside. Once they are removed (slide out to side) the last larger connector (black) has some wires, of which you will need to locate,-1) Red/Blue -- power2) Brown -- earthThese are much thicker than the others, and a little difficult to work withRemove 5 cm of the black taping around the wire loom, and splice in 2,5 m wire to Red/Blue1m wire to BrownThe "power" wire must be routed up to the fuse box behind the gloveboxThe "earth" is grounded to the bolt holding the seat rail when screwed inIf all is correct the side bolsters should pump and deflate on command :top:REMEMBER to disconnect battery first, and take precautions not to loch yourself out of car or boot during operation (windows open , cloth over inside boot latch) ...Ill get pics up soon in the meantime , take this link to more info http://www.e90post.com/forums/showthread.php?p=8021941#post8021941
