Repaint Rims in Penang
yee7402
Planning to respary my rims, which shop in Penang can do a good job, anyone can reconmend? How long will the new paint last normally?
Theres one shop where they repair and paint rims at Berapit near BM...they done a good job on 18incher from my prev car(paint & polish)... fgt the name and the business card is at home la..maybe someone else can shed some info here...im sure many northerns are familiar with this shop as they are famous..
Must be Dunlop tyre shop Berapit
Repainting rim workshop kl or pj
Hi UDM Guru's....
To avoid creating another similar topic or new tread, can I tumpang here also. My e90 rims need repainting/spraying too. Is there any place in kl/pj which can do the job well? I need a shop which can provide a spare rims coz I need to use the car for work. Looking for Quality and good workmanship.
Pls advise. Tx.
Wheel painting can be a relatively simple DIY process. Unless you're going to powdercoat it, you can get good results using a proper spray paint.
Longevity of the paint depends on your prep job. Flaking and bubbling can be almost eliminated if you spend some effort on the prepping of the wheels. I've personally done it once, and the last I checked (at the 1.5 year mark) there is no flaking or chipping of the paint, and there is no discoloration. I've other friends who've done it and had only good things to say.
After all, its maximum a weekend of DIY labor and the cost is just for your paint. Good thing is that if you're not happy with one color, you can always just respray it yourself at minimal cost :D
darvic76;541229 said:
Hi UDM Guru's....
Pls advise. Tx.
I know this person Michael 016-6922102 offer the spare rims when u leave your rims to refurbish in his shop at Kepong.
Anyway, do a proper introduction mate.
Guys, Thanks for all the advise.. Am going to check out a few tyre shop this week...
Planning to downsize my current 18 to the original 16 and have it spray paint gun metal...
Miss the look of my car on 18" but what to do need a more comfy ride and I cannot find a 17" wheel that I like and have easy access to in Penang..
If anyone know where to get a good spray painter in Pg, pls do let me know..
Bro, When will U be back in Penang.. If I can get the name of the shop or the location that will be great..
hi all....
just some feedback.
i spray painted my breytons last time but all the brake dust fused into the lacquer and cannot be removed.
better powder coat.
What is the different between spary paint and powder coat?? I want something that is lasting..
Alek Spray in Kg Gajah beside KIA showroom they done good job.
Will be home only on 2nd week of next month..they call it dunlop shop at BM but its at Berapit town..by the way you should check out on spraying glasurit paint on wheels..:top:
VKS, Is it call Speed Alloy, heard about that shop, plan to check it out later tomorrow after work if time permits..
Putra, where is this Kg Gajah, KIA showroom??
Putra, where is this Kg Gajah, KIA showroom??[/QUOTE]
LEK Spray
Tan Hock Eng
79 Jln Kampung Gajah
12200 Butterworth
Tel. 04-3318033
hp. 012-4658989 / 012-4836683
"The main difference between a conventional liquid paint and a powder coating is that the powder coating does not require a solvent to keep the binder and filler parts in a liquid suspension form. The coating is typically applied electrostatically and is then cured under heat to allow it to flow and form a "skin." The powder may be a thermoplastic or a thermoset polymer. It is usually used to create a hard finish that is tougher than conventional paint." -wikipedia
Price will be your deciding factor. But then again if its just some stock 16" wheels...can spray yourself ma :p
time to BUMP this thread... just another pgkia looking to respray rims to matte black. Did we find the name or number of the shop at berapit?
thanks.
thanks.
Try this contact no 045385975 / 045395080
Sam Lian Tyre - Berapit
not 100% sure, you can try
