Recommendation for Exhaust System and Suspension Kits for an e38 740iL
JonRaj
Hi all,Was wondering what would be the recommended exhaust system for a 740iL (e38) that can be gotten in Malaysia which produces a deep V8 sound and possibly some added power?Am also toying with an idea of fitting on 19" rims and whether the original suspension kits should be maintained or it should be changed to the aftermarket mods. Advice please.Price indications for both above is much appreciated.Thanks
There aren't many exhaust options for the E38 in Malaysia. I would suggest Supersprint as they have a specific design for the 740il.
If you fit 19s you will need to lower it, with original suspension it will look very high off the ground.
Jon Raj,
If its an iL, then its easy to fix the height issue. The rear is adjustable, and the front just get titan to customise and lower the spring retainer. Can even go for Hi-Lo kit (not my cup of tea) but do-able..
The issues with E38 is the large fender to fill. Even at 19" you have to lower the car otherwise.. "empat jari" on front. and tyres are seriously painfully expensive.
