Rattling Sound From Rear Wheels On Uneven Roads
shefee8128
Hi,I'm having this problem for the past 1 month. Whenever the car goes on an uneven road, there will be a rattling / clicking sound from the rear wheel.This can only be heard while the window is down. There has not been any changes in the ride behavior / comfort .What could be the problem? Has anyone experience this before?Thanks.
Hi, in my case there's some funny sound when i drive on an uneven road but found the culprit.. Its actually my rear back seat not properly installed.. Some clips not attached. When i changed my rear deck, the sound went off coz i did reinstall the seat properly again. My e46's rear seat clips are mostly plastic to metal.. Try add some dampening first coz probably its not from your rear wheel.. Otherwise try check your wheel bearing.. Probably gone dy.. If still have some sound, maybe you can consult further with your regular mechanic.. Try cheaper solution first.. Mine is e46 btw..
My 2 sen..
rear wheel bearing prob la kot..ive experienced that lovely sound before..fix it around rm8++ for both rear bearing..
