Astronyu
- Dec 3, 2010
- 312
- 18
I saw someone selling this Quadcore High Performance plug cable which the brand claims to increase HP and reduce FCInstalling HPPC will make the rev lighter, better pick up and getting lower fuel consumption. Beside that, this HPPC can stay higher temperature than the ori do.The only side effect is maybe will create some radio interference. But so far more than 500 HPPC that i sold, only 1 (4G92 Mivec using RAM 8.2mm HPPC) facing little bit radio interference. Reason causing this is found out and now more side effect after this. So you can use this HPPC with confidence.Items: Quadcore™ 10.0mm and JEC 8.5mmPrice:BMW320 E30 6 cylindersRM280 Quadcore™ 10.0mm
Is this really reliable? I mean, can I use it on my dear E60?
