Power window dont have auto up
tweiboon
1 of my power window dont have auto up, is it the power window problem or can be set my BMW scanner 1.4 ?
try power window switch from other door in that place...(very easy to take off) and if it works..it must be the switch...
my last problem with the switch was due to the broker pcb track..which can be rectified quite easily
first if really the switch problem then how come the master switch and the rear window switch also dont have auto up ? Second i have tested the rear switch which switch over 2 doors and found out the switch dont have any problem
tweiboon, this looks to be configurable in bmw scanner 1.4.0. ZKE5 coding under one-touch function
taken from http://www.bmwclubmalaysia.com/foru...on-BMW-Scanner&p=610704&viewfull=1#post610704
alright..now we know that its not the switch problem..
was the door closed when u tried to operate the window coz auto wont work when the door is openned.
before you start coding ..try this
1. close all doors.
2.turn the ignition key ON (dont need to start the engine)
3. press and hold down button for 5 to 10 second after the window reach the bottom
4. then press and hold the up button for 5 to 10 seconds after the window reach the top..
this to reinitialize the window
1. close all doors.
Just done what you mentioned but still no use. Still dont have auto up but got auto down for right rear window.
Thats an improvement..
Next, skip the down step..just do the up reinitializaton..switch off and test again
This also done for few times but still no use. You said auto wont work when the door is opened, but all the while my windows will auto up and down when door is opened.
Have you checked anti trap/pinch strip along the top of the door frame..? Try to run and press your fingers along.that black rubber lining and run the init process again
i dont understand what you mentioned. Can you give more details ? This auto up not work after i change the power window lifter.
Some even says that u have to press and hold the swith for about 30 seconds...
Ahhhh..
I seee...after you replace the window regulator, the only thing that you have to do is reinit the windows...thats all..
Auto up not working after i change the power window lifter, is it because i change the lifter or others problem ?
So reinit the dont must done at the rear right window switch with at bottom hold the button 30 sec then at top hold 30 sec ?
Since u got the auto down working now..i would say u have to do the autoup only...bring the window down..switch off the key..wait for a while..turn on the key, press the up button and keep pressing it for additional 30 secs whenthe window reach the top...turn off the ignition..and back on...fingers crossed..it should work again
i just tested but still can not make the auto up. Where you stay can you do it for me ?
Where can i buy the rear right power window anti trap rubber ? What is the price of this rubber ?
