jumi
- Apr 8, 2010
- 99
Dear forumer,sifus and otai of e34,I need opinion on my engine problem.Currently my car running on m20b25 auto.Now facing problem on radiator keep losing water.need to topup everyday.Most of cooling system item such as radiator,termostat,hoses, water pump has been replace and recently replace the pipe in between the clutch fan also. except the clutch fan.And also temp gauge on speedo meter showing the temp slightly more than half when i stop or in idling position.But in driving condition the temp on the dot.Is it normal?All the item I replace at Albert workshop.Accoding to Albert it could be a clutch fan fault or cause of head gasket.And he said to me that may be top overhaul needed.Here I need you guys opinion which is better to way to solve my problem.Either to do top overhaul or just change to m50b25 halfcut.If possible i would like to solve this problem at minimun cost due to my pocket already koyak.Hope you guys can help me.Thanks in advance.
