Fadhlan
Official Member
- Aug 2, 2010
- 1,779
- 113
Onkyo TX NR-616 Home Theater Receiver with 3D HDMI
Here we have a used Onkyo TX NR-616. The home theater receiver was bought brand new in June 2013. The reason for the sale is to upgrade to separates - pre & power amp.
Expect outstanding all-round performance from the Onkyo TX-NR616 home theater receiver. Its THX® Select2 Plus™ badge of certification means it can reproduce riveting, accurate movie sound that'll have you glued to your TV screen. You also get the latest surround sound options, including Dolby® TrueHD and DTS-HD™ Master Audio, two high-resolution formats found on many Blu-ray movies. The 'NR616 uses Onkyo's WRAT (Wide Range Amplifier Technology) and a high-current power supply to deliver dynamic, punchy sound that stays clean even at higher volume levels.
You can also expect amazing video quality with the 'NR616's Marvell Qdeo™ processor. This circuitry is designed to show you all your favorites, new or old, at their best. Plus eight HDMI inputs — including one in front for easy access — let you connect all your high-def equipment. And let's not forget that there are two HDMI outputs to connect to your TV and projector. But movies, video games and TV are just the beginning.
Teeming with entertainment options
Just plug your iPod® USB port to get the beat started. This direct digital connection delivers a pure digital signal to the 'NR616's superior processor so your music sounds awesome. Use the Ethernet port to connect the 'NR616 to your broadband home network, or if you have a wireless network, you can use Onkyo's optional Wi-Fi® adapter. Either way, you'll get easy access to the music files stored on your networked computers. Then dive in to thousands of Internet radio stations — so you can enjoy entertainment from every corner of the Earth. Your potential playlist just went exponential. Add to that the ability to stream music from Internet streaming sources like Pandora® Internet radio, Spotify®, Sirius/XM® Internet radio, Rhapsody® and more (may require registration and subscription fees).
Real ease of use
The 'NR616 comes equipped with Audyssey® sound-shaping tools, to automatically balance and equalize the sound based on your room's acoustics. Plus Dolby® volume maintains optimum dynamics, so gone are the commercial sponsor's surprise attacks of sound. Onkyo's InstaPrevue™ system lets you see thumbnails of digital video sources on-screen, taking out the guesswork of which source is plugged into what port. You also get a graphic user interface to make control easy and intuitive with overlays on your TV screen. And you can download a free app to use your iPhone®, iPad® and Android™ devices as powerful Wi-Fi® system remotes.
Highlights:
Power and Processing:
7-channel amplifier
100 watts per channel into 8 ohms (20-20,000 Hz) at 0.08% THD, with 2 channels driven
THX® Select2 Plus™ certification guarantees pristine home theater sound
Dolby® TrueHD, DTS-HD™ Master Audio, Dolby® Digital Plus, DTS-HD™ High Resolution Audio and Dolby Pro Logic® IIz
Audyssey DSX® processing for enhanced surround sound height or width effects using additional front speakers
analog-to-HDMI video upconversion (up to 1080p) with Marvell Qdeo™ video processing
Audyssey 2EQ® auto speaker calibration (microphone included)
Audyssey Dynamic Volume™ mode to maintain steady listening levels
Audyssey Dynamic EQ™ for fuller surround sound at lower volumes
Digital Music Options:
direct digital connection of iPod®/iPhone® through front-panel USB input allows music control via receiver's remote
DLNA (Digital Living Network Alliance) certified to ensure optimal compatibility with other network-enabled equipment
Wi-Fi ready, requires separate adapter
Internet streaming capabilities for Internet radio, Spotify®, SIRIUS/XM® Internet radio, Pandora® Internet radio, Rhapsody® and more (may require registration and subscription fees)
Bluetooth integration (requires optional optional Onkyo adapter)
Multi-room Audio:
three-room/three-source output:
powered and line-level stereo audio output for 2nd room (using powered 2nd room stereo output allows 5.1 home theater in main room)
line-level stereo audio output for 3rd room
Audio Performance Features:
high-current amplifier design
192kHz/24-bit Burr-Brown digital-to-analog converters for all channels
direct mode switches off unnecessary circuitry to provide cleaner sound
back surround speaker channels re-assignable for bi-amping compatible front left and right speakers
Music Optimizer function enhances the sound quality of compressed music files
Connections:
1080p-compatible HDMI switching: 8 in (including 1 front-panel input), 2 out
HDMI version 1.4 with support for 3D video, Audio Return Channel, Deep Color, x.v.Color, auto lip-sync, and HDMI-CEC
Audio Return Channel function receives digital audio signals from a compatible HDTV's tuner via HDMI
digital audio inputs: 2 optical and 2 coaxial
5 audio/video inputs, including:
1 front-panel input with composite video
4 rear-panel inputs with composite and component video
no phono input — to connect a turntable you'll need to add a phono preamp
Ethernet port for music streaming from a PC network
2 audio outputs for powered subwoofers
1 pair of main speaker outputs
General features:
overlaid on-screen display via HDMI for easier setup and operation
40 AM/FM presets
multibrand remote
Onkyo's free remote app lets you use your iPod touch®, iPhone® or Android™ device as a Wi-Fi remote
17-1/8"W x 6-13/16"H x 13-3/8"D
weight: 11kg
Cash on Delivery at any destination in the Klang Valley. Buyer will need to pay exact shipping cost for delivery outside of KL area.
Real ease of use
Highlights:
7-channel amplifier
Multi-room Audio:
Connections:
General features:
40 AM/FM presets
multibrand remote
weight: 11kg
