OBD-II trouble code P0171 Fuel system too lean (Bank 1)
Status
Not open for further replies.
QD250
Founding Member
Guys,been having the above trouble code on/off over the past 1 month.Anyone experience this?What did you do to correct it?Thanks.
QD250;548435 said:
Guys,
Thanks.
Try cleaning your MAF sensor. Also could be due to failing O2 sensor.
QD, 2 other possibilities. a small leak in the intake (probably near the boot) or even failing/weak fuel pump.
Fuel system too lean meaning not enough fuel in the combustion. For combustion to ignite perfectly, the air fuel mixture must be right. Too much fuel is "RICH", too little fuel is "LEAN". Lean means more air than fuel.
1. Clogged injector.
2. Weak fuel pump.
3. Clogged fuel filter.
4. Faulty fuel regulator.
5. Fuel hose terlipat.. :p
6. Can also be faulty O2 sensor because giving false alarm.
7. Faulty MAF also possible.
8. Weak spark plug.
9. Faulty ignition coil..
10. etc.. :eek:
Bank 1? U only have 1 Bank.. :p Only V engine got 2 banks.. :p
QD250;548435 said:
Guys,
Thanks.
bro, what are the symptom?
No power? - tekan minyak also car cannot go
High speed OK?
erratic idling speed?
FC High?
white smoke at exhaust?
QD...got this code also in my car last time...i cleaned the MAF sensor then ok liau...but there could be other factors that could cause this as well as listed above...
2. Weak fuel pump.
8. Weak spark plug.
10. etc.. :eek:
AB, you very knowledgable la.. :adore:
Bro QD,
This is from E46Fanatics.com. Hope it will help
OBD II Fault Code
* OBD II P0171
* OBD II P0174
Fault Code Definition
* OBD II P0171 Fuel System Too Lean (Bank 1)
* OBD II P0174 Fuel System Too Lean (Bank 2)
Symptoms
* Check Engine Light will illuminate
* In some cases, no adverse conditions may be noticed by the driver
* In other cases, there may be performance problems, such as a lack of power on acceleration and some "coughing" or misfiring
* The vehicle may have trouble idling, especially when warm or when sitting at a stoplight
Common Problems That Trigger the P0171 and P0174 Code
* PCM software needs to be updated
* Vacuum leaks (Intake Manifold Gaskets, vacuum hoses, PCV hoses, etc.)
* Mass Airflow Sensor (MAF)
* Plugged Fuel Filter or weak Fuel Pump
* Plugged or dirty Fuel Injectors
Common Misdiagnosis
* Oxygen Sensors
Polluting Gases Expelled
* NOX (Oxides of Nitrogen): One of the two ingredients that, when exposed to sunlight, cause smog
* HCs (Hydrocarbons): Unburned droplets of raw fuel that smell, affect breathing, and contribute to smog
The Basics
Combustion engines operate by burning an air/fuel mixture of about 14.7 to 1-14.7 parts air to 1 part fuel. When the air ratio goes below 14.7 parts, this is called a "rich" mixture. If the air rises above 14.7 parts, it is called a "lean" mixture.
Rich Mixture = Too much fuel, not enough air
Lean Mixture = Too much air, not enough fuel
To keep the engine running properly, the Engine Control Module measures the oxygen content in the exhaust with oxygen sensors and makes adjustments to the mixture by injecting more or less fuel.
The control module operates within specific parameters and under normal conditions, it will make minor adjustments to the air/fuel mixture. When these adjustments become too large, a fault code is set. When the P0171/P0174 code sets, the oxygen sensors are detecting too little oxygen in the exhaust and the control module is adding more fuel than normal to sustain the proper air/fuel mixture.
P0171/P0174 Diagnostic Theory for Shops and Technicians
When a vehicle has the fault code P0171 and or P0174, it means that computer can no longer automatically adjust the mixture between air and fuel. Code P0171 applies to Bank 1 and P0174 applies to Bank 2. Code P0174 mainly applies to V6 or V8 engines because 4-cylinder engines generally have only one bank, though there are a few exceptions. Some of the high performance 4-cylinder and straight 6-cylinder engines (such as those in BMW and Lexus) split the cylinders into groups of two or three and call them separate banks.
When the code says that the Fuel System is "too lean," it means that the computer has been adding more and more fuel, which is called Long Term Fuel Trim. Ideally, the Long Term Fuel Trim should be close to 1 to 2 percent. When a code P0171 is set, it means that the Fuel Trim is anywhere from 15 percent to as high as 35 percent compensated. When this happens, the computer knows that there is an improper condition in the control of the Fuel System.
The first step in the diagnosis of a code P0171 and/or P0174 is to look at a minimum of three ranges of the Long Term Fuel Trim numbers on a scanner. Check the idle reading-3000 RPM unloaded and 3000 RPM with at least 50 percent load. Then check the freeze frame information for the code to see which range(s) failed and what the operating conditions were.
Before we get into the main causes of P0171, let's explore why this code matters.
Why Does a P0171/P0174 Code and Running "Too Lean" Matter?
"Lean" running cars and light trucks are highly polluting vehicles. Most of the NOx pollution, which is poisonous and can cause asthma, is caused by vehicles that are running too lean. A lean running car can also misfire, which puts raw fuel (HCs) into the atmosphere. When you are behind a car or truck that smells bad and makes your eyes burn, it is misfiring and running too lean. In comparison, a "rich" running engine has no smell (CO is odorless) or you may detect a rotten egg smell, which is caused by the Catalytic Converter consuming too much sulfur, like when you are behind a big SUV at full throttle going up a long, steep hill.
P0171 is not an Oxygen Sensor problem. Before a P0171 code is possible, the computer first ran a series of tests to validate the readings from the oxygen sensors. Since the oxygen sensors passed their readiness tests and didn't set any codes, the computer then looked to the Fuel Trim adjustment. When the computer determined the air-to-fuel mixture to be too lean, it then set the P0171 code.
What Are Some Common Causes of Code P0171/P0174?
Always check to make sure that there is not a PCM software update due or available. Often, as the vehicle's engine wears, the PCM's Fuel Map software inaccurately compensates for this condition. The fuel mixture grows lean and eventually, the code sets.
A vacuum leak is very common. It could be a torn PCV hose, a torn Intake Air Boot, or even a broken seal on the dipstick (the dipstick is a part of the PCV system and if it does not seal, too much unmetered air will enter the engine). Don't rule out a sticking/leaking EGR Valve or leaking EGR or Intake Manifold Gasket. If it is a V6 or V8 engine and the code is only on one side/bank, it could be a defective Intake Manifold Gasket or cracked/leaking manifold.
What if There Is No Vacuum Leak or Both Codes (P0171 and P0174) Set?
An "under reporting" Mass Air Flow Sensor can be a common cause of a code P0171 and P0174. Essentially, this means that the Air Flow Sensor is telling the computer that much less air is entering the engine than actually is.
Since the oxygen sensors are telling the computer that more fuel is needed, this causes confusion in the computer because the Mass Air Flow Sensor is still saying there is too little air and the Oxygen Sensor is reporting that the mixture is still too lean. The computer tried to compensate, but since resolution is impossible, it sets the code. It is important to restate that the Oxygen Sensors are accurate-the fuel mixture is too lean. In this case, the Air Flow Meter or Sensor is inaccurately reporting the real amount of air entering the engine.
How Do I Know if the Problem Is the Mass Air Flow Sensor?
There is a very effective "truth test" for any Mass Air Flow Sensor. Start the engine, let it idle, and then check the Barometric Pressure reading on the scan tool data. If the reading is about 26.5 Hg and you are close to sea level, you know that you have a defective Air Flow Meter because it is telling you that you are at about 4500 feet above sea level. (These conversion tables will help.) When the Mass Air Flow Sensor sees this Barometric reading, it adjusts its Air Density table and then "under reports" the actual amount of air entering the engine. It does this because the Barometric Pressure Sensor is actually part of the Mass Air Flow Sensor.
Sometimes the Air Flow Sensor and the sensing wire get covered with dirt, dust, or oil residue, which can also set a P0171. Cleaning the sensor might hold off problems for a while, but eventually, the MAF sensor should be replaced. Always make sure the Air Filter and its enclosure are dirt-, dust-, and oil-free. If you clean and replace the filter and its enclosure as needed, you will prevent the new MAF from failing.
Additional Causes of Code P0171/P0174
* A plugged Fuel Filter or poorly functioning Fuel Pump can set the P0171 code. The computer hears (accurately) from the Oxygen Sensor that the Fuel Mixture is too lean so the computer keeps increasing the amount of fuel being delivered into the combustion chambers. But in this case, the Fuel System can't increase the amount of fuel.
* If you still can't find the problem, be sure to check and verify that fuel pressure and delivery are at spec. If fuel pressure and volume check out okay, scope the injectors and perform injector drop and/or flow tests to see if they are capable of delivering enough fuel. Dirty/contaminated gas can definitely plug injectors and trigger these lean codes.
Will look into cleaning it this weekend if i have the time...... may also clean the whole air intake system...
2. Weak fuel pump.
3. Clogged fuel filter. changed my fuel filter in June 07, maybe time to change.....
8. Weak spark plug.
9. Faulty ignition coil.. coil changed 2 months back...
10. etc.. :eek:
hhhmmmm....
High speed OK?
FC High?
power is okay.....
tekan mau pegi aja....
high speed ok...
no erratic idling....
FC also okay...
no white smoke....
hhhmmm....
went searching for the CRC MAF sensor cleaner yesterday at several places but could not find it....
finally found CRC QD Contact Cleaner which is similar based on the forum in UK.....
so last night...... DIY and cleaned my MAF.... also took out the whole air intake and cleaned it too.....
about midnight went for a test run..... hhhmmm..... response was good..... tekan and it wants to go to redline all the time....
now to find the time to reset the fault code and see whether it lights up again....
QD make me want to clean my MAF.. glad that you manage to solve some issue with your car.
Hi QD,
Happy that you solved your problem...
I've been having the power drop & erratic idling with engine check light as well...
Been hunting for the MAF cleaner as well...
Not sure if you could help me out a bit...
KNRaj;549252 said:
Hi QD,
thanks...
look for the CRC QD Contact Cleaner.... similar item
if you come to Official TT tonight, ask me and i'll tell you where to buy it....
join as OM and i give you the whole can....
:top:
QD250;549626 said:
thanks...
:top:
Raj, if you join, I help you DIY on the spot with QD250's MAF cleaner. :wink:
Raj,
It is really a bargain of a lifetime !! and personal service from our sifu Jarance. If you send your car to any BMW workshop, they will not clean the MAF and instead will replace the MAF costing about RM750.00.
the CRC MAF cleaner is available at Brothers Ampang, taman dagang. RM 37
Hey Folks, (QD250, Jarance, Herbert)
You guys rock! Sounds interesting... I feel should become OM ASAP!...
I think I've missed the TT as I was in Penang last weekend...
When is the next? Still bleeding with the same problem with my ride thought...
Check Engine Light, MAF, etc - still no luck in my part
Dear Mr Jarance, and fellow forummers,
I have this Check Engine for almost a year now and too bad, my supposedly "expert mechanic" from "Autobavaria" (now ex-AutoBavaria employee) still could not manage to find the actual problem in my 2003 E46 320i (Japan Spec, V6 220 CC).
I have been asked to replace so many parts including O2 sensor, MAF meter, etc and all of them solved the CEL temporarily. After 2 or 3 days it reappear. The codes spelled out "Fuel Trim Lean". Recently, after installing Mass Air Flow meter and with the CEL reappearing after 3 days, he started saying that the car need top overhaul and ECU replacement. CRAP!.
After confronting him about his poor diagnosis and "trial and error" approach, he insists that this is the way to go (replace one by one of possible "culprit") which I think an absolute irresponsible act (I hate to say either he is truly incompetent or trying to be mischievous). I have spent more RM than I anticipated with this guy and I am loosing my patience for his incompetency.
Is top overhaul is the answer? My car never had overheating problem (I don't know of its history in Japan though) and it only has 110K km on its odometer.
OR upgrade of ECU is the other possible answer? What is PCM upgrade?
Is there any other better alternative workshop out there who can help me?
Best regard to everyone and thanking your advice in advance,
- Moe
Status
