Noise When Turning Left
James Chun
I heard a loud "clicking" noise when my car in stationary & I turn the steering to the left...I can hear "click click click click"...... annoying!!! What can be wrong? any comment???
When i experience the samelast time , it was the lower arm + bush. Get it check at the mechanic. Most of the time the sound is noticeable when the arm is loaded, means when you jack the car up the sound will be minimal.
yeah bro, should be the arm/bush. it could be low in power steering fluid too. do check that. no harm checking :)
its the steel cone in the tie rod, when you replace the tie rod there is a small steel cone there, i had the same problem, it cracked.
