hi bros..mine was acting weirdly for the past few weeks....gear seems to be sluggish in changing...& when the accelarator press hard it will kickback as usual but the problem is.....it will automatically behave like sport mode & there is no cruising gear@ 4th gear anymore...even after slow down , stop the ignition & restart back, the gear behave the same....only the next morning, when its cold, & i step the accelerator pedal lightly, then the gear shift normally, but if suddenly step hard then the problem start.....i've drain & change the tranny oil & filter but no improvement...really need opinion from u guyz.....do u think that this is a solely gearbox problem or anything to do with the electronics?...thanks....
