need a workshop to do general overhaul for E46 318i
skywalk16
hello, require cost for general overhaul of E46 318i and suggested workshop. Looking for a reasonable price:cool:
go to M sport at Aman Suria. Good workmanship and reasonable price assured. look for jason or kenny. contact 0166264663 jason aka ah keong.
Hi Bro
There you go..
Below are the details.
Keong (016 626 4663)
M-Sport
No 46-1 Jalan PJU 1/3B Sunway Mas Commercial Centre
47310 Petaling Jaya
skywalk16;673875 said:
thx... i'm a new bimmer too, pls suggest the size of sports rimm should i get
if u have to ask...just stay with the stock ones for the time being until u know what u want :cool:
Why you wanna overhaul Bro? How long have you been driving the car and what is the problem that needs such major overhaul?
Aman Suria is located near to Bukit Mayang Mas and Tropicana. M Sport is the corner shoplot just adjacent to the Kg Cempaka new village.
there's oil in the radiator, probably due to head problem n oil leaking underneath engine. top up oil every 2 wks time
Leaking is a common problem in e46. Maybe should go get the workshop to give advise. Dont think you need to overhaul the car at this moment in time.
BMW 318i e46 auto.
Hi all, Newbie here.
mine have a same issue here, top up oil every 2 wks time...what should i do? pls advise..thanks
due to ur problem better u check 1st..check the heat exchanger (engine n gearbox) mayb got leakage or crack there..
Hi bro u did mention e46 318i but what model ,n43,n42 ,and what year. common problem to overheat and cause the silinder head gasket to burn,or it may cause of engine oil leaking , before u do anything i sugest u try comprasion test the silinder's to c wheather your piston ring wear or not .check it first ,good luck.
Bro, 1st of all, welcome to the club.... By just doing a simple search in this forum, you can get tones of info you r looking for. For the starter...
http://www.bmwclubmalaysia.com/forums/showthread.php?55-E46-parts-amp-maintenance
http://www.bmwclubmalaysia.com/forums/showthread.php?13918-E46-Part-and-Service-Cost-II
http://www.bmwclubmalaysia.com/forums/showthread.php?440-List-of-Workshops-We-Go-To
http://www.bmwclubmalaysia.com/forums/showthread.php?6314-List-of-recomended-workshops
http://www.bmwclubmalaysia.com/forums/showthread.php?246-List-of-Good-Workshops
hope this would help.... Cheers.
Bro skywalk16 & fir3works,
I just recently overhauled my car due to oil leakage, oil in the radiator and the cyclinder start to misfire. As advise by our Sifus here,bring you ride to the workshop and get it checked. Check the head if there`s any leakage as well. Just getting the car overhauled is not tht really bad on the costing. I do forked out about RM2k+ unless you change some other parts also which depends on the parts condition.
Dont worry.....
bro Balan37, can you share what was done/changed during your overhaul? RM2k+ seems very very reasonable......
Mspeed near SS 26 - call Ah Wah 019 2429 229 - good job reasonable price.
Terry:cool:
