My UDM
initialM;444225 said:
After parking my E46 for 3 days suddenly cant start the car, batt flat. Damn!
Change to Century Maintenance Free DIN66.
How much did this set you back?
My E46
Repair the speedometer button. The trip & setting button not working. Thanks to my trusted accessories sifu for saving me from changing the meter. Now all my electronic are in working condition:top:
Inner side of speedometer
Broken button
My E46
At last managed to check out the rear booth inner compartment. Lucky everything still good. Stripped everything in the booth & check the spare tyre.
Give a good cleaning job. Just look at how dirty the water
My E46
After clean & let it dry before install everything. Next would be my ICE project.
Will update soon once completed.
bmw7833;445525 said:
Bro, your tyre letak terbalik lar..
No lar that's the correct way for 3 series. E36 also same. U can see the black plastic rim cover where u can keep things also:wink:
initialM;445529 said:
No lar that's the correct way for 3 series. E36 also same. U can see the black rim cover where u can keep things also:wink:
Sure..?? But u see the gold color plate???? It should be slot into the rim center bore to prevent the rim move or 'jump', right ?
Aiyah no lar the plate already locked the plastic cover that hold the rim. Dun confuse wt E39.
Bailey;445618 said:
tis guy KING of maintenance wat ??????? good job bro
ha ha ha ..must send my car to initail M for a day or 2 for cuci cuci , kilat mengilat ... :)
My E46 ICE project
My E46 ICE
1) Ori BMW Head Unit
2) Vibes (UK) 6.5" component front speaker
3) Epsilon 5" component rear speaker
4) Epsilon 12" subwoofer
5) 2 Channel Cerwin Wega amps to drive front speaker
6) 2 Channel Rottweiler amps to drive rear speaker
7) 2 Channel Earthquake (USA) amps to drive subwoofer
8) Lanzar Electronic Crossover
After clean up all items in the booth do all the ICE wiring
All front part taken out & clean
Bro - when were the pictures of you cleaning the rear bonnet taken? Was it last Sunday before we met or just recently? I thot ur E46 was already sparkling/gleaming last Sunday - never mind the E39 which was spotless! Hai.. untung la jadi kereta-kereta Bro initialM nih....
My E46 ICE
Front Vibes component speaker
All 3 amplifier install on custom made board.
12" EPS subs with custom made thick board box. Install back all clean carpet & board.
Now my E46 ICE has completed & can boom boom boom while driving hehehe
No bro this project started on Mon & just ended today:top:
This is first time I stripped the booth interior before doing the ICE:listen:
My E46
Since already taken out the front console take the opportunity to install carbon fibre sticker for the trimming. Now interior part got new fresh look of aluminium brush/black carbon fibre combo:top:
