i need help, is changing the motors inside the mirror or change a total whole new side mirror like a m3 one is cheaper?any cheaper options beside pushing the mirror to change angle?:0
If both, then check the fuse lah. The fuse box is located in the glove compartment.
Just open the glove compartment and look at the top. You should be able to see 2 knobs. Twist the knob and the fuse box compartment will "dropped" down. there is a white chart to tell you which is the correct fuse to check.
no the mirrors can tilt.. just not in some directions.. ie can go up and down not left and right.. i think the gears in the actuators are busted.. thats why ask whether chagen the motor inside is cheaper or buying a new side mirror like m3? or is there any other alternative mirror beside m3? thx for bearing with me
ya ya thats the one.. to be exact the right mirror cant go up down can go left right.. the left mirror can go left right cant to up down.. guess its the mirror's fault right?
Jarance,you impress the hell out of me with your pictures,knowledge and details and most importantly your patience and kindness to share:top::top::top:
