My E60 525i : From Terengganu With Luv
bro BJM7978,
Mind to share where you bought the "Decorative Clips with Screw (Steering Cover) : RM350" and is it for E60??
Coz mine is peeling and looking fugly
Kunta_Kinte;653569 said:
Bro, DVD Navigation tu OK tak? Worth tak dengan harga RM250 tu?
Currently I'm using Garmin ajer .. boleh update selalu..
Sebab DVD yang ada Europe punya .. :(
u can try my cd..i will make a copy n then let u know..
:motz: I am experiencing a tick, tick, tick sound when my car is idling after a cold start.. After 2 to 3 minutes it fades away. Ones the engine's warm it doesn't occur again..any opinion guys?called my mechanic and he suspect the alternator or might be pulley..already changed belt and tensioner a few months ago..here the video i took with my bb this morning :
[video=youtube;QTHEq7ziIbQ]http://www.youtube.com/watch?v=QTHEq7ziIbQ[/video]
:listen: .. sounds like your tappet bro but its kindda loud......clearance too wide kot, can be adjusted though....send to halim to have a look at it bro. :4:
here the another video :
[video=youtube;yOrSRQ_9Jd0]http://www.youtube.com/watch?v=yOrSRQ_9Jd0[/video]
teppet tu apa bro?:ahhhhh:
bengkel halim kat mana?
Beserah :4: ... hope this will not be considered a commercial posting .... :4: ..no personal commercial value :4:
As for you main Q, tappet is actually "sound of a worn cam follower" ... bila injin sejuk, clearance lebih besar, thus the louder sound. Bila da cukup panas, it expands and the clearance is reduced thus lesser or no sound. Tappets (some call it lifters) selalunyer last as long as the engine, usually longer with better care. Periodic Oil and filter change is good enuf to keep it running good. Though reliable, ada drawbacks gak; valve clearances periodically require adjustment as the contact surfaces of both tappet and valve stem will wear.
Di mana tappet terletak?? ... kalau di overhead cam engines, camshaft is directly over the valves :top:
Cheers bro ...
Found this from e60.net
SUBJECT
Intermittent Hydraulic Valve Adjuster (HVA) "Ticking" or "Rattling" Noises
MODEL
All E83, E85, E86, E60, E61, E70, E90, E91, E92, and E93 with the N52 or N52K engines
SITUATION
An occasional ticking or rattling noise from the HVA elements may occur during cold engine starts or
frequent short distance driving.
CAUSE
In these situations the HVA elements may have not yet been supplied with sufficient amount of air-free
oil. This condition will not cause any damage to the engine and usually remedies itself with a longer
driving distance or operating times at full operating temperature.
CORRECTION
In the event of a customer complaint please perform the following the HVA bleeding procedure.
PROCEDURE
Important notes:
The bleed time may take anywhere between two minutes and (in rare cases) a maximum of 30 minutes.
This procedure is to be performed on a level surface with the vehicle stationary, and in a properly
ventilated area.
Procedure preconditions:
Engine oil level correct � neither under filled nor overfilled
Engine running at operating temperature
1. Bring the engine up to an operating speed (no load) of 2000 � 3000 rpm and maintain this condition
for three minutes (bleeding procedure).
2. Let the engine idle for 15 � 30 seconds and reevaluate if the noise is still present or not.
3. Engine quiet � Procedure is finished.
4. Engine noise is still present � Repeat procedure � Steps #1 and #2 up to a maximum of 5 times.
5. Only if the noise remains after performing the bleeding procedure 5 times � proceed by performing
the procedure for a final time, also at an engine operating speed of 2000 � 3000 rpm, but for a total time
duration of 15 minutes.
WARRANTY INFORMATION
Covered under the terms of the BMW New Vehicle Limited Warranty.
SI B 11 09 07
Engine
July 2007
Technical Service
Page 1 of 3
http://www.bmwtis.net/tiscode/cgi-bin/omcg...tm_store/9397... 12/26/2007
Note: The following explanations will spell out the correct use of the work times.
Defect Code
11 12 94 39 00
Labor Operation 00 57
087 Perform bleeding up to three times
Main Work
Labor Allowance 5 FRU
088 Perform bleeding 5 complete times
Main Work
Labor Allowance 7 FRU
089
Perform bleeding 5 complete times plus additional 15 minute
bleed run
Main Work
Labor Allowance 11 FRU
717 Perform bleeding up to three times
+ Associated
Work
Labor Allowance 3 FRU
718 Perform bleeding 5 complete times
+ Associated
Work
719
bleed run
+ Associated
Work
Labor Allowance 9 FRU
Main Work: Use this labor operation number when the only repair performed is the
listed warranty repair.
OR
Page 2 of 3
+Associated
Work:
Use this labor operation number when other repairs or services are
performed along with the listed warranty repair.
Under no circumstances should both labor operation numbers be claimed.
Attempts to claim both times will result in an unnecessary delay in claim
processing and payment.
Cheers bro ...
oraikk bro..will pay him a visit..must be fixed before raya ni..:banghead:
:listen: ..tak perlu risau sgt bro, tak rosak pun injin ... cuma bunyi jer yg kurang menyenangkan di pagi hari ... :4: ...
Raya preparation
15-09-2011
Oil Filter : RM 65.00
7L engine Oil(Castrol Edge 10w60 ) : RM 385.00
See Wide, Terengganu
BM auto Garage, Johore
15/10/2011
Rear Bearing RM195.00 x 2
Rear brake Pads RM 395.00
Brake Sensors RM70.00
Labour RM190.00
Plan to change my car color to space grey..any suggestion/comment guys?i'm tired of maintaining the dark blue color,Water mark and swirl mark are obvious if not well taken care..
