Fireuz;592742 said:Sabaw bro.. kete tu walaupun kuat tedarah minyak, tp byk jasa touuu... The smaller second car would be the best idea..
initialM;592981 said:I think there is power leak somewhere. It happened to me also till managed to find the leak after 2 days left at wireman place.
Now no problem even left the car for 1 week without starting and engine will start in 1 crank.
initialM;593010 said:Check your foldable side mirror. Is it still functional without ignition key on?
initialM;593028 said:This means the side mirror motor is all the time on hence drain the battery power. Redo the wiring so that it can only function when ignition key is on.
azeL_Inc;593053 said:my side mirrors function the same way.can be operated with ignition off. so far havent had any problem, and wouldnt hope for one![]()
initialM;593096 said:No problem if you drive almost daily but eventually the battery will flat some day
Gerald 5;593106 said:No, I have to press the button to fold it. Usually i don't do that unless I park at a narrow road. What I meant to say was, even after I turn the ignition off I still can press the button and get the mirrors folded for the 1st I think about 10 mins. After then, it can't be folded anymore unless I on the key again.
