If your original spec front brake disc thickness is 22mm, after machined, the thickness should NOT be less than 20.40mm. If 10mm for rear, minimum is 8.4mm.
And after machined the discs, you should use new set of brake pads..., NEVER use old pads on new discs...
Good luck!
