M5 side mirror
Realred78;519183 said:
Bro,
Who can do the installation? Do the mirrors fold automatically when the engine is switched off?
You can wire to do such or use a toggle switch to do that func. Your choice :)
from the mirror, how many wires? Right now, I see 6 in total, with a set (of 2) in brown and red(I assume power) while another 4 lumped in one corner in different colours. Using a batt, I found that the mirror can only go up/down, left/right. Sucks :)
u r rite ....thanks ......
hv u try the wire of set of 2 ???????/
did try but nothing happened. the insides of the mirror near the neck area also looks empty as if no motor
One other way to confirm got motor or not inside, try folding your mirrors manually. If you hear a click sound (like gears locking), means got motor inside. But don't have to fold completely to hear this. Just a little twist at that point, you should be able to hear it.
Is it hard to DIY the folding mirrors? thinking of sticking on a set.
no sound. Just smooth movement.
To install them, you need to remove your door panel, tweeter cover. Be prepared with door panel clips. Good to have special tools so that you don't waste time removing and installing the door panel again. Be careful of the airbag too. Hehe.
Connecting is straightforward if your car already has the folding side mirror feature. If not, need some wiring skills
bono2k;489777 said:
alo bros...
Anybody got M5 e39 side mirror for sale ? the electronic foldable and come with the signal light, of course.. pls pm me with pic and price.... tqvm
hai.i can get 4 u if like can sms me 0199868542
Can anyone recommend a good wireman who knows the E39 wiring and set up? I have foldable M5 mirrors installed. But left side mirror does not fold. Cheers!!
May I know how did you do it? I was having the same problem but soon decided to do it the ori way. You would need 2 modules. One at each side.
Lionel_Koh;518993 said:
The new stock arrived .......
E39 with memory
E36 sedan and coupe with memory ....
Call 0122207630 if interested ....
TQ
Lionel
Do you sell the motor for the M5 folding mirror
bimmer73;525891 said:
Lionel
Harbajan, I think you are right.
Both mirrors fold when connected directly to the socket on the right side. But when connected to the left side, only the adjustment of the glass and the memory work. The folding function for the left side does not.
Lionel, do you anyone who has fitted these power folding mirrors to an E39 that originally does not have folding function?
Yes.....a lot cos most of d e39 here without d auto fold function....
Just a simple wiring to connect d fold function....
