m42 clutch
McFir7
recently when to source for m42 clutch set.one shop gave me a m40 twin mass clucth plate.he said can use wit m42.but i doubt cause the main diffrent m42 n m40 clutch plate wit or without the 4 spring in the center only.but diametre the same if i m not mistaken..so can use m40 clutch set on my m42 engine.by the way mine is a manual tranny
Which car is the engine from?
Factory M42 clutch plate is different from the M40 ones depending on which flywheel design it is using.
m40 single flywheel use the clutch that has built in springs
m42 double flywheel uses the springless clutch as the flywheel itself has a builtin spring mecha
clutch is matched with the flywheel, even if there are some original twinmass ones, some owners change them to single mass, best is to remove it, then go look for a similair one if you are not too sure
the m42 engine from a e36 coupe...
the m40 clutch from luk is a twin mass clutch wit spring..what clutch u guys r using anyway?
Just take your original clutch (for measurement) and get to EXEDY for a triangle plate as what i have done
TQ
TQ
whats the different feel n performance wise?mmm how much does it cause bro?
any problem if using exeddy?
